2009 KLX250 Aux. tank is ready
Sold through Baker DistanceTanks, the aluminum 1.1 gallon auxiliary tank for the 2009 versions is now ready. The full kit includes the replacement coolant bottle, line, petcock, cap, filter, hardware and instructions.
The price for the 1.1 is $275.00
The website is still under construction.
http://www.bakerdistancetanks.com/
Our tanks are constructed of aircraft grade aluminum 5051 alloy in .063" thickness. This is the same material used in Cessna single engine aircraft. All welding is by certified aircraft welders. It doesn't get any better than my guys.
Here are a couple of photos of the final fit check on production tank A
Here are pics of the tank installed on the 2009 model.
There will be a website 10/11 or 10/12.
Baker Distance Tanks is a separate company but will be working with B&B to develop new products. For instance, there will be auxiliary tanks for the KLR650 next.
By special order, yes, I could do that. That would require probably 2 weeks. It would be the same tank but a different bracket set.
