2006/07 KLX300 Brake lines on a KLX250S?
Old 07-29-2015, 02:37 AM
vlodpg's Avatar
Default 2006/07 KLX300 Brake lines on a KLX250S?
Anyone know if 2006/07 KLX300 Brake lines will fit on a on a KLX250S?
Buy One, Get One! Galfer Stainless Steel Brake Lines (11 Colors!)
Thumpertalk.com special!
DESCRIPTION
LIMITED TIME OFFER - BUY ANY GALFER OFF-ROAD & DUALSPORT MOTORCYCLE STAINLESS STEEL FRONT BRAKE LINE AND GET THE REAR LINE ABSOLUTELY FREE! THAT'S A $47.00 SAVINGS!
THIS OFFER EXPIRES ON AUGUST 3rd, 2015 (PST). PLEASE ALLOW 2-3 BUSINESS DAYS FOR NON IN-STOCK COLOR COMBOS TO BE BUILT FOR YOUR ORDER. OFFER DOES NOT QUALIFY FOR FREE SHIPPING OR COUPONS.
BEFORE YOU ADD TO CART:
>>> Click HERE to see if Galfer makes brake lines for your make/model. <<<
Base price ($59.00) includes silver banjo fittings, with colored banjos at an additional $10.00 per line (2 lines). All line cover colors are included in the base price save Platinum at an additional $10.00 per line (2 lines).
Stainless steel lines offer better brake lever feel over stock.
Stainless steel lines offer better braking performance over stock.
Custom line and bango colors simply look cool!
Made inthe USA.
Lifetime warranty
Instructions for most applications.
Full-time brake line technician on staff available for support.
Virgin PTFE.
64 lines of steel braid.
Pre-positioned banjos for easy installation, although adjustable as needed by hand.
Galfer’s off road brake lines feature a heavy-duty stiffener sleeve over the hose to route just like the OEM units. Kits come complete with banjo bolts and washers.
Most of our brake line kits come with labels on the lines to help guide you on which end goes where, something not found with any other manufacturers today. We also offer a lifetime guarantee against any manufacturing defects.
Old 07-29-2015, 05:23 AM
vlodpg's Avatar
I found that the OEM part numbers for the 07 KLX250 & 300 are the same for front/rear
Old 07-29-2015, 10:01 AM
KLX25O's Avatar
BOGO?
I'd get um'
Nothing but good things to say about Galfer brakes.
the most expensive brake line you can get.
Old 07-29-2015, 11:41 PM
vlodpg's Avatar
Just ordered a set, hope they fit!
Old 07-30-2015, 05:32 PM
miniman's Avatar
What are the part numbers that you used? I have a 2007 that I would like to add the ss lines to. Does yours have that solid line running under the fork leg? Will the new line use that or run directly to the caliper?
Old 07-31-2015, 02:38 AM
jacksonriding7's Avatar
Location: In North Western Jersey, but from Jackson, WY Originally
Ditto the above question on if these lines will replace that steel one. Every time I look at that I picture it smashing on something when I dump it and leaving me brakeless
Old 08-01-2015, 12:22 PM
vlodpg's Avatar
This is what I found when looking up part numbers for the 2007 KLX300 VS KLX250S
HOSE-BRAKE,FR
43059-1693 KLX300
43095
HOSE-BRAKE,RR
43095-0164
43095
HOSE-BRAKE,FR
43095-0163 klx250
43095
HOSE-BRAKE,RR
43095-0164
Edit: Mine has the solid line line but I see the schematic diagram for the KLX300 also does!
Old 08-03-2015, 04:29 PM
miniman's Avatar
I went ahead and ordered them, we'll see if they fit when they get here. Fingers crossed.
Old 08-04-2015, 12:28 AM
MaximusPrime's Avatar
I ordered some too.
How different can they be? I guess we'll find out...
I'm hoping the front is a wee bit longer than the '09 and up stock line.
The rear is the same.
Old 08-04-2015, 07:37 PM
drm's Avatar
drm
drm is offline
ordered a set too...
Quick Reply: 2006/07 KLX300 Brake lines on a KLX250S?
