1996 Klx 250 gearbox problem
Just to start off hi new here so be gentle,
I bought two klx 250 one is 1996 only 21000 in very good condition with a gearbox problem, the other is 1998 thats got 32000 miles not so good condition but engine box excellent condition,
What the 1996 klx is doing it runs very well when I get it started so carbs need cleaning but that's another post, when I start the bike in neutral then put it in first start to ride the bike I can get it sometimes up to third then it will start to wind with no drive in any gear, when I stop and try find neutral the light come on and it's still wineing when I let the clutch out, if I put it into first the wineing stops as though its in neutral, it I leave it for a day or so it will find a gear then do exactly the same when I ride it.
I'm making one good bike to do green lanes, the other I'm stripping down to do a full rebuild to have a show piece, any help would be a great hope, not much experience with these gearboxes
Yes, sounds like a clutch issue to me also.
Do you know how to open the side to get at the clutch, inspect plates, etc? Do you have access to a factory service manual?
Also check to see that your clutch cable isn't overly tight. There should be a little bit of slack when the lever is fully released.
I check that, I've got the engine on the table in the workshop as I need to replace the spline that rounded off so may as well do that, I think it's more that just a cable, I'll go inside have a look at the clutch,
Just wandering if someone had a engine block of a older klx mines a 1996 that may be a better option or a complete engine I would have that
