Please help with choke issue klx125
This is a 2005 klx125 4 stroke.
Hi I really need to help with this carburetor issue I am usually good with carbs but I have not run into this issue previously l. the choke is not working properly. Instead if being normally pushed in and needing to be pulled out for engagement, it's the opposite. The choke valve is pulled out and you have to push it back in via the lever and hold it there to disengage the choke, which obviously you can't drive it while holding the lever all the time. Does anyone have any suggestions ? I doubt a carb rebuild would solve this issue. Thanks
Last edited by Amn28210; 04-22-2017 at 07:53 PM. Reason: Forgot to put info on the bike
Captain Kuhle
07-24-2011 05:41 PM
