Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
Problems Idling
Old 04-16-2008, 07:28 PM
adamharris's Avatar
Default Problems Idling
I have a 2003 KFX 400 and the motor has a hard time staying at one idle speed, It will periodically idle up then idle back down by itself, Also when your riding it and you let off of the gas and pull the clutch in it doesn't idle back down immediately it stay reving kinda high then it will eventually idle down. Any suggestions
Old 04-27-2008, 03:48 AM
hunter's Avatar
Default RE: Problems Idling
What's up? If I were you, I would take it right to a Kawi dealer. Problem is, if you are all stock, you have a very sensitive carb. If your idle adjustment screw isn't helping, you have some internal issues. Is it jetted? Once again , internal problem. Have you taken the airbox lid off. Alot of guys remove the lid to increase air flow and occasionally require re-jetting. If you're all stock, probably need a carb rebuild. Bad gas, the list is long.......
adamharris
04-20-2008 03:40 AM
TAG
02-07-2008 04:42 PM
Quick VR4
10-30-2007 09:40 PM
JaBr1884
Ninja 250R
23
07-17-2007 03:13 PM
Max
05-06-2007 02:00 AM
Quick Reply: Problems Idling
