Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
KFX 450R won't start...
Old 12-22-2008, 01:22 PM
madvandale's Avatar
Default KFX 450R won't start...
I have a 2008 KFX 450R that won't start. I got it in the water a few weeks ago. It ran fine til I parked it in the garage. The weather here has dropped to around 30 degrees since then. When I turn the switch on, The nuetral light is dim, you can't hear the fuel pump kick in, and it wont roll over. acts just like the battery is dead but it is checking out as full charge with no dead cells. I'm thinking I might have gotten moisture in the wiring but I'm not sure. Anyone have any clues?
Madvandale
Old 12-22-2008, 01:43 PM
start unplugging molex connectors and blowing them out. the coil wires and fuse box too.
good luck! and welcome to KF
Old 12-22-2008, 02:28 PM
Is that a FI motor? Otherwise I would say drain the carb bowl, re-fil and get the battery charged up. Then try.
Old 12-22-2008, 02:36 PM
madvandale's Avatar
Default RE: KFX 450R won't start
What and where are the molex connectors? I am new to this game. And yes it is fuel injected. The battery is fully charged and tests out perfect. The power just isnt making it to the bike. I will try to blow it out.
Thanks,
Madvandale
Old 12-22-2008, 03:09 PM
sorry molex connectors are the big plastic connectors on all the wiring. water can get in there and cause a short.
Thanks,
Madvandale
Old 12-22-2008, 07:28 PM
madvandale's Avatar
Thanks. I will check it out.
Madvandale
Old 12-23-2008, 01:07 AM
kx slaughter king's Avatar
does it turn over at all? does it make any noises when you try to start it? and have you checked your oil yet?
Old 12-23-2008, 11:20 AM
madvandale's Avatar
No, it doesn't even turn over. One time you can hear the starter clutch spinning, then next time it won't even turn. And you could always hear the fueul pump kick in and shut off before it started, but now it doesn't even kick in. I do need to check the oil, though. It is do for it's first service. Only have about 15 hours on the bike.
Old 12-23-2008, 02:44 PM
Hey Welcome to KF, Hope you figure out the problem soon,, Def check the oil. Good Luck
When your done Post up some pics PLZ
Old 12-29-2008, 06:53 PM
madvandale's Avatar
HEY!! GOT IT FIGURED OUT!! After talking to the shop and you all on here, I tore the whole bike down and checked every connection. Still nothing. So,I called my dad up and explain how p*ssed I was. He is an old school machanic and a simplist. He told me..."OK, your battery has voltage but how about ampage?" That was it. Tested the battery and it had a full charge but was only putting out 1 amp. Got me a new battery and it runs like a dream again. I do want to thank you all for your input. I wouldn't have had a clue of where to even start without you.
Quick Reply: KFX 450R won't start...
