Kawasaki Quad's & ATV's Quad (Leisure) & ATV (Working) talk within here.
1988 mojave 250
Old 04-21-2012, 01:47 AM
georgefarmer's Avatar
Default 1988 mojave 250
Ok well ive got an 88 Mojave that ive been having some problems with. It starts up and will idle fine but then when I press the throttle and give it gas it starts to cut out and die. It started this after my friend ran it wide open on the highway for a couple minutes straight and then it started sputtering and cutting out like it had ran out of gas but it seems to be getting gas just fine so I don't know if something serious might be wrong with it or what? Your help would be much appreciated.
Old 04-21-2012, 03:29 AM
Welcome to KF
Running a ride WFO (Wide Fukin' Open), will suck up a lot of sediment that is in the float bowl. The float prolly ran low and sucked up anything it could. I would try either a fuel treatment, or a carb cleaning and adjustment. Being an '88 I would prefer the carb tear down, cleaning and adjustment since you did not mention the last time it was done. You also did not mention how the plug looked.
Old 04-21-2012, 03:56 AM
BleednGreen68's Avatar
I agree with drag, probably dirty carb since it dies with throttle. Probably main jet plugged. I miss my 2000 Mojave, fun lil atv!
Zizata
09-10-2009 08:27 PM
ezdaar
07-01-2009 10:58 PM
dmojave250
01-29-2009 02:18 PM
Mojaveman
10-29-2008 02:31 PM
barrons03
02-22-2007 04:28 AM
Quick Reply: 1988 mojave 250
