rear drive shaft leak
Just noticed my rear drive shaft is leaking fluid. When I pulled on the drive shaft it came part of the way out of the housing and of course leaked much more oil. What part has failed, what holds the drive shaft in the housing?
It is a 2007 Kawasaki Mule 3010 4X4.
Thanks for your help
Hi,
On the 3010 mule ,, ( gas or Diesel ,, All the Same Internal Drive-line Parts )...
the Rear In - Board half-Shafts ARE held in place with a Snap Ring .
There is a Spacer between the inside bearing race , and the snap ring .
The bearing itself is held in the housing / mount with a large snap ring .
NOW , On the LEFT Side ( driver side ) Of the Tranny/ Rear Diff . there is a gear that sides on the Shaft ,,, This is the Rear Diff Lock .
Why, did it break ,, problem is the " spline/ sliding inside the rubber boot .
It gets Rusted Up,,
Things to check ,, 1 ,, Out Board axle Bearings ,, 2 ,, Make SURE the Half-
Shaft U-joint Yokes are In-line (( Mark The Shafts At The Splined Ends With White Paint ,, It will make Easier to line up the shafts )) !!!! ,,3,, Clean splines / Slip Joint ,,4 ,, Rubber Boots ,, 5 ,, Use Waterproof/ Marine Grease .....
Hope This Helps ,
Later ,
Mark K.
It gets Rusted Up,,
Hope This Helps ,
Later ,
Mark K.
Rear Driveshafts Leaking
Hi,
Here Spme Pict's .
first - Rear drive shaft With U-joints Alined ,
Second - Rear Inner Drive shaft tranny mounting plate, the pen is pointing
to the Snap -Ring on the shaft , ( Note ; There is a Spacer missing behind the snap- ring in this picture , )
Hope this helps ,
Later,
Mark K.
Here Spme Pict's .
Hope this helps ,
Later,
Mark K.
GDub
07-16-2017 01:08 PM
