Mule 3010 fuel issues
hi everyone, i bought a 03 mule 3010 a couple of weeks ago, when i bought it (knowing it would need some work) it was very hard to start and would crank forever before it actually started. The previous owner said it was his dads and had sat for around a year, after cleaning the carb and putting new gas in it still wont start, I know the fuel pump is bad but i dont think it is getting any power too. Does anyone know why this could be or where to get the pricey fuel pump cheapest? thanks
if your positive the pump is not getting power then the most obvious cause would be a blown fuse assuming the fuses are in the same location as the 2510 it is under the drivers seat if the pump is bad go to NAPA or any other trusted parts supply house and buy a low pressure inline 12v fuel pump and an inline fuel filter it will take a small amount of modifications but it will be significantly less expensive than the oe pump
