2007 3010 trans mule, blowing 30amp main fuse. NEED HELP
Old 09-30-2015, 03:59 AM
BruceEddy's Avatar
Default 2007 3010 trans mule, blowing 30amp main fuse. NEED HELP
I was driving the mule and it just quit. After checking for the problem I found that the 30 amp main fuse was blown. I replaced the fuse and as soon as I turned the key, it blew again. I have found that one side of the fuse terminal is grounded. I have traced the ground back through the switch and I have hit a road block. I can find anything that would be causing a ground on the acc side of the switch. I think I have moved every wire and unplugged everything I can find in the front and it's still grounded. Acts like its the brown wire that is grounded.
Old 10-09-2015, 12:32 AM
CrashWrench4010's Avatar
Default Mule Blowing Fuses
Hi,
Q. , Is This a Diesel ??
If it Is,, First try Removing the wire off the glow plug , Replace the fuse ,
(try it , But Do Not Start ! ) If The Fuse Does NOT "blow " , Then one or more of the " Glow Plugs " Are ,,, Burned / Shorted Out .
If the Mule is still Blowing the fuse, Remove the Positive (+) wire off the Alternator , Try again , If the Fuse holds ( No Blow - OK ) The Alternator is Shorted Out . Last ,,, Check The "" Power Outlet Socket "" On the Dashboard ..
Hope This Helps,
Later,
Mark K.
Old 10-24-2015, 12:38 AM
Hi Bruce Eddy ,,
Did you find your problem ?
Please post What you found ...
Thanks,
Mark K.
Uyless1
06-09-2019 04:25 PM
chromedome
02-23-2017 01:38 AM
Shadygrady
10-09-2015 12:48 AM
dsmracer
08-25-2009 08:36 PM
dsmracer
Ninja 250R
08-18-2009 12:08 AM
Quick Reply: 2007 3010 trans mule, blowing 30amp main fuse. NEED HELP
