08 3010 trans diesel starting issues and smoking.
Old 02-05-2014, 12:24 AM
Chetos's Avatar
Default 08 3010 trans diesel starting issues and smoking.
Hello everyone,
The above mentioned mule is hard to start after it sets and when it does start, it misses and blows blue smoke for about 30 seconds and then idles correctly and stops blowing smoke. I am thinking a head issue possibly valve seals, but not sure. Any input would be greatly appreciated. It just turned 1900 hours.
Thanks for your time.
Old 04-20-2014, 01:23 AM
shadynasty82's Avatar
like most diesel engines the combustion chamber needs to be preheated before cold starts this is where the glow plugs come into play I would check the preheat (glow plug) circuit first before you tear into the head or valve train
Old 10-09-2015, 01:12 AM
CrashWrench4010's Avatar
Hi ,
+ 1 on checking the glow plugs ,
Also if this mule sets a long time between runs , Take your fuel filter Off , Look
inside / pour into a clean Drain pan ,, If It Is Nasty Green Algae Fungus , Then need to Flush the fuel System ... ( Low Sulfur fuels have a lot of water,, make things GROW!!! )
Last If the Glow Plugs are Ok ? might have a Leaking Injector ,
Hope this helps ,
Later,
Mark K.
Uyless1
06-09-2019 04:25 PM
OKCMULE
01-09-2018 09:27 AM
chromedome
02-23-2017 01:38 AM
AClark
03-30-2016 07:22 PM
Shadygrady
10-09-2015 12:48 AM
Quick Reply: 08 3010 trans diesel starting issues and smoking.
