Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
stx 15f problems again
Old 04-09-2011, 12:09 AM
john15f's Avatar
Unhappy stx 15f problems again
Hi any won had problem with jet ski display turning on even when key is of
just come out off shop 4 weeks to fix jet unit and even when picking up display turns on then off and flashes battery shop told me to charge battery
i have done that and still display turning on after 10 seconds the sometimes flashes on and off like it would when you first turn on key then stays on
slow mode displaying and will not cycle display modes
before jet unit fixed i did have speedo and smart steering mode only work intemitently
can some one tell me what to try
regards john25f
Old 06-17-2012, 08:34 PM
Adam Russell's Avatar
@John15f
I'm having the same issue. Did you find a resolution?
Old 06-19-2012, 03:18 PM
john15f's Avatar
Default Fixed
Kawasaki make a **** display that is not water proof
Remove display pull out rubber stop drain out water causing
Problem clean with isotonic alcohol and allow to dry this may fix the problem or the display will need to be replaced in America
Kawasaki have replaced even after warranty in australia the told me bad luck
I plan to remove display yearly and check for water
Do not used high pressure hose on display sponge clean only
I still did replace display 800 Aussie but old display was working except showing 12 v low when no motor running
Hope this helps
Regards John 15 f
Old 06-20-2012, 01:57 AM
Thanks for the reply John. Tonight I worked on removing the meter to inspect for water leakage. It was kind of a pain to disassemble but I eventually was able to get at it. Was there an easier way to get at this meter? I took the Hull Middle Fitting, right hand mirror, and pad handle off. After all that, I was able to see the meter bracket and screws. I haven't disconnected the wiring yet but I could tell there was definitely water present and some of the circuits look corroded. I am going to order the meter assembly right now.
ufo777
08-18-2009 04:19 AM
duke
07-29-2009 04:17 AM
gs350on22s
07-28-2009 01:10 AM
sickawi06
09-09-2007 06:22 PM
Nutter78
10-04-2006 06:57 AM
Quick Reply: stx 15f problems again
