Kawasaki Jet Ski's One, Two & Three Passenger Jet Ski talk within here.
1993 750 SS Not Cooling Engine
Old 07-27-2010, 11:12 PM
dmack1's Avatar
Default 1993 750 SS Not Cooling Engine
There isn't any water coming out the bypass on the side. I ran it for awhile then it stalled out and wouldn't run.
Old 07-28-2010, 12:07 AM
so you are saying that you ran out of coolant and seized the engine? Good luck, just guessing right now on the worst case scenario
Old 07-28-2010, 11:04 AM
dmack1's Avatar
I didn't realize it was not cooling until it stalled out. When I brought it back to the dock and checked it out. I was hoping it stalled out before I seized the engine.
Old 07-28-2010, 11:30 PM
dmack1's Avatar
I believe the engine did not seize. I have compression in the cylinders and can see them moving, with the plugs out.
The problem now, it won't start without starting fluid and when it starts and you run it, it has no power, when you hold the throttle all the way in, it goes very slow. ANY IDEAS?
juan romero
05-20-2012 12:46 PM
Scott Smith
05-08-2012 07:18 PM
Israel-klx250s
03-04-2012 08:33 AM
wakeboarder82420
06-29-2009 03:31 PM
coondog
05-27-2006 09:59 AM
Quick Reply: 1993 750 SS Not Cooling Engine
