96 Zxi won't start
96 Zxi won't start
Hey guys, i'm new to the forum and I don't know much about Jetski's but learning on the fly. Went to start my ski and can't get anything out of it. New battery, won't crank, no gauges, no clicking. Would a bad starter be the problem or am I looking at somethinhg else like a fuse, etc.?
RE: 96 Zxi won't start
I have the same problem, no gauges but trim works, put in a new battery and checked all connections but everything looked fine, then I decided to open up the grey box and found water in it and that 2 of my main wires were broke from corrosion, once I repair these wires hopefully this repairs the problem.
Well thats what it was, 2 broken wires and alot of corrosion, caused by the salt water im guessing, repaired them, cleaned up the corrosion and fired up right away. If your going to crack open the grey box, make sure to put some gasket maker on it after, if you find water in it that is.
