2001 STX 1100 DI -- reduced rpm's ???
Hi! Wondering if anyone heard of this happening. It appears that after sucking up some seaweed (and cleaning it out with a pressure washer), I now have a condition where it won't rev up. Normally I can get 7000 rpm out of it, now it only goes about 5500 rpm and all else seems normal. The ski has 100 hrs on it and has been pretty much babied as far as maintenance. I thought it was a clogged line to the brain box but that would trigger the slow mode with 3500 rpm max. There is no signs of the engine running hotter than normal. I would appreciate any advice. Also, would like advice from someone on a 1990 Seadoo Rotax twin carb with a fuel flooding / hard starting problem. Thanks, Steve R.
