1994 750 jet ski boggs and stalls in the water
I've seen this before with similar kawasaki jet skis, but I'm not sure what causes it. I can get the ski to rev-up fine out of the water but as soon as I go to ride it IN WATER, it only idles for about 20 seconds and eventually stalls. When I go to accelerate, it stalls. ???
RE: 1994 750 jet ski boggs and stalls in the water
I have a 84 Kaw 550 jet ski that does the same thing. I started it on my pickup and it had lots of power, and when I put it in my pond it was very doggy. Slow ride around the pond.
Hello 750,
Have you fixed the problem yet? What is the compression reading on your engine? It seems your problem is related to either the engine or jet pump impeller/bearing, but not the carburetion, since it happens only when there is a load (water). How easy is it to turn the jet pump shaft?
scrtch111
05-04-2012 05:13 AM
gsrcivic9
04-12-2011 02:04 AM
molinaman98900stx
04-01-2009 02:50 PM
rickmedina
06-10-2006 05:41 AM
