Go Back   Kawasaki Forums > Other Vehicles > Kawasaki Jet Ski's
Sign in using an external account
Register Forgot Password?
Search
Reply
LinkBack Thread Tools Search this Thread
Old 06-28-2011, 01:26 AM
Default 03 stx-r 1200 taking on water
whats up guys. what i have here is a 2003 stx-r 1200 that is taking on water... never had the problem before motor is strong and runs fine but the first time i went out this season i noticed it was taking on water. first time out i hooked up to my anchor n noticed ski sinking slowly. the plugs were in n i have no holes in the hull at all..it took on almost enough water to cover the battery does anyone on here have any idea what it could be? gaskets? seals? thank you in advance
Register now for free or log-in if already registered to remove this ad!
Old 07-20-2011, 05:57 PM
Not much activity on this forum this year.
Did you ever solve this problem?
My skis are older than yours, but in general....
Leaks are either bad coolling hoses or connections, bad driveshaft bearing seals or mount, or bad thru-hull fittings or cables (trim / reverse cables). You already ruled out drain plug or hull damage, and you don't even want to think about a cracked block.
If its leaking that bad, just stand in shallow water and look inside. Or haul it out on the trailer with water inside (careful... too much water can overload the trailer design) and look to see where it drains OUT.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
