Oil Leak
Oil Leak
I have a slight oil leak in the upper end gasket--1997 1500 classic
Advice on using a "STOP LEAK"
Also, can synthetic oil be used?
bEEN READING THE FORUM HERE, ON OIL OVERFILL. I had changed at dealer and I feel he overfilled it. I noticed my recipt and it stated 4 qts. I beleive that is 1 to many. (filter changed) anyway, a month later these small leaks started. Could this had an effect on seals and gaskets. The leak is comming from the top end fromt, underneath the crome cover.
Thanks for the help!
RE: Oil Leak
no problem, wish I had more specific advise. I'm not familiar with your bike, so it could be a common thing with an easy fix, or a 'problem' that'll involve more complex repair. Did the leaks continue after the oil level was corrected?
Oh, as for stop leak, I'd stay away...it treats the symptom not the problem, and only temporarily.
