Mikuni TM 36 68 pumper carb
Old 04-18-2014, 07:35 PM
banarne71's Avatar
Default Mikuni TM 36 68 pumper carb
Hi!
Foundation two carb son eBay. Both have the same name and number and are told in text that they are pumper Carbs. The thing is that they look very different. Any thoughts about it?
Mikuni Geniune TM 36mm 36 mm Flat Slide Smoothbore Carb Carburetor TM36 68 | eBay
Mikuni TM36 Flat Slide 36mm Pumper Carburetor Accelerator Pump Spigot TM36 68 | eBay
Which one would be the best to buy?
New member with his first Kawasaki.
Old 04-18-2014, 08:02 PM
dpippin's Avatar
Originally Posted by banarne71
Hi!
You want the second one.
The first one is not a pumper.
This is the one to use on the KLX250
Old 04-18-2014, 08:13 PM
banarne71's Avatar
Hi dpippin!
I have a klx300r. So it's the pumper one that's the one to go for. Is that a bettet choice than to buy a dynojet kit for the original carb?
Old 04-19-2014, 03:36 AM
dpippin's Avatar
Hi dpippin!
I have a KLX250S that has been modified to 300 with the KLX300 cylinder and piston and exhaust, so it's basically a 300 now.
I had rejetted the stock carburetor and it ran quite well.
Later I installed the pumper carb and it made a huge difference in performance.
So you can learn from others.
In my opinion don't waste your money on a dynojet kit. Get the TM 36-68 pumper carb.
It may require some jetting changes but there is lots of information with what to start with.
Here's a couple of links and do some searching for more information.
Search for posts by mustang and TNC
https://www.kawasakiforums.com/forum...q-links-30733/
https://www.kawasakiforums.com/forum...s-13648/page2/
Be glad to share my jetting info if you need it.
Doug
Old 04-19-2014, 05:40 AM
banarne71's Avatar
Thanks dpippin!
I will consider a pumper carb instead of a dynojet kit. I'm now working on installing a road kit and will soon be out on the gravel roads and in the forest.
Sid Post
12-03-2012 11:31 AM
jonathan76
10-10-2011 01:24 AM
RDHJ
04-11-2010 01:40 PM
toomuchdust
08-14-2007 11:25 PM
EMS_0525
09-09-2006 05:53 PM
Quick Reply: Mikuni TM 36 68 pumper carb
