Mikuni TM 36 68 pumper carb
Hi!
Foundation two carb son eBay. Both have the same name and number and are told in text that they are pumper Carbs. The thing is that they look very different. Any thoughts about it?
Mikuni Geniune TM 36mm 36 mm Flat Slide Smoothbore Carb Carburetor TM36 68 | eBay
Mikuni TM36 Flat Slide 36mm Pumper Carburetor Accelerator Pump Spigot TM36 68 | eBay
Which one would be the best to buy?
New member with his first Kawasaki.
Hi!
The first one is not a pumper.
This is the one to use on the KLX250
I had rejetted the stock carburetor and it ran quite well.
Later I installed the pumper carb and it made a huge difference in performance.
So you can learn from others.
In my opinion don't waste your money on a dynojet kit. Get the TM 36-68 pumper carb.
It may require some jetting changes but there is lots of information with what to start with.
Here's a couple of links and do some searching for more information.
Search for posts by mustang and TNC
https://www.kawasakiforums.com/forum...q-links-30733/
https://www.kawasakiforums.com/forum...s-13648/page2/
Be glad to share my jetting info if you need it.
Doug
