lighting failure
Old 07-14-2007, 08:57 PM
Hawk's Avatar
Default lighting failure
I have a 96 vn800 a and the tail light, brake light and instrument clustrer light do not work. All fuses are good and all connections are good. The bike starts and runs fine and the headlight comes on after start up. The turn signals work and so does the horn. HELP ! ! !
Old 07-14-2007, 08:58 PM
Hawk's Avatar
Default RE: lighting failure
Does anyone know a way to get a wiring schematic on line ?
Old 07-14-2007, 09:47 PM
Crazy Chewy's Avatar
I know you can usually find some cd's on ebay but if you know how to use a multi meter I would start checking voltage and wire continuity. start at the junction box and work your way out to the lights from there. take your time it is usually frustrating but you def. will find the issue that way
Old 07-15-2007, 12:29 AM
A meter is the greatest tool just under the knowledge level. I will check my archives for a diagram.
Old 07-15-2007, 12:35 AM
ok, I only have the VN 750, 1000,1200.1500,1600, and 2000manuals But I am sure that you could cross reference, since diagrams are normally close for a few years.
CokeyoDrips
10-17-2011 04:25 PM
FM_Thumper
05-12-2009 12:47 PM
RODDISM
Ninja ZX-14
07-13-2008 04:01 PM
DABBE
Ninja ZX-10R
04-06-2008 07:22 PM
xyz1000rr
01-28-2007 02:28 AM
Quick Reply: lighting failure
