Help! My bike will not rev past 5000 rpm
Old 09-21-2005, 04:11 AM
hammerbyte's Avatar
Default Help! My bike will not rev past 5000 rpm
I have a four stroke twin Kawasaki EX500 which was sitting for a few years. Just put a new battery in and got it running and inspected, but have a question about a little bug. Under load, it will not rev past 5000 rpm, so it will only go about 60 mph. Not under load (in neutral), it will rev past 5000 rpm. Do you have any idea what could cause this? Any ideas would be greatly appreciated! Kim
Old 09-21-2005, 04:11 PM
Gerg's Avatar
Default RE: Help! My bike will not rev past 5000 rpm
Hmmm... Do you hear any odd noises when it refuses to rev higher? It almost sounds like it's not able to hold the higher compression... Which brings to mind all sorts of bad things that could be wrong. Of course, it could be something simpler, but it's hard to tell.
Have you tried all the other typical tune up stuff? spark plugs, clean carbs, etc... ?
Old 09-21-2005, 09:56 PM
LayinFrame's Avatar
yea i would deffinately start with the basic tune up first exspecially after sitting so long
Old 01-07-2006, 09:19 AM
Fattkaw's Avatar
Concider it a blessing. Keep you out of trouble.
Fattkaw
Old 01-08-2006, 01:30 AM
hammerbyte's Avatar
What fun would that be?
Old 01-09-2006, 08:59 PM
motogprocks's Avatar
under a load.. it sounds like it might not be getting enough fuel pressure.. while under a load..
Do the clean carb change fuel filter thing first.
Old 01-10-2006, 02:24 AM
Bluebeast's Avatar
check you hoses too. you may have a cracked vaccume hose some where if it's been sitting so long.
p-howekx250
07-12-2023 09:23 PM
canehdian_guy
09-10-2014 05:20 PM
GearHeadGTP
Classic Touring Bikes
12-21-2012 03:05 AM
Robert24
06-21-2011 12:17 AM
bmx_lar
04-13-2010 10:06 PM
Quick Reply: Help! My bike will not rev past 5000 rpm
