Air/Fuel Mixture Screw Adjustments - Kawasaki Forums
Reply
LinkBack Thread Tools Search this Thread
Old 05-06-2006, 07:49 PM
Default Air/Fuel Mixture Screw Adjustments
On my 2000' ZX9R, which has a Muzzy Full Titanium Header on it, has been re-jetted with only the Main Jets increased in size. Stock being 160's on the outside carbs and 165 on the inside. I changed them to be 165 outside/170 inside. The bike is full of Power especially in the midrange and upper rpm's.
The question that I have is on the fuel/air mixture screws.
Kawasaki's Service Manual states that stock is set at 1 5/8 turns out on all (4), but the plugs are running white at that ratio. I turned them to 1 3/4 turns out, but they are still white.
I then cranked them to about 1 7/8 but still white.
I just turned them to about 1 15/16 and will have to check on it after a bit of riding. Last year when I set them to (2) complete turns out, I had flames coming out of the exhaust. That was with a k & N air filter, but I put that back to stock filter w/screen out.
I there another reason my plugs may be on the lighter side?
Old 05-06-2006, 10:43 PM
Default RE: Air/Fuel Mixture Screw Adjustments
you need to check the plugs after you run it for a bit
Old 05-07-2006, 04:13 AM
BigRig18Wheeler's Avatar
Yup, it's a real fine line.... Mine is two turns, but at night on a no load rev, she'll shoot a little bit of flames also.. Put 4800 miles in the last 4 months that way, and no prob.. If I screw any less turns, she just doesn't run right. If I'm cranking on her driving, she won't shoot flames tho' ...
Also, if the plug is all ready burnt the ceramic.. you might try a new set of plugs, then redo your test a 1 15/16 ...??
Old 05-07-2006, 04:22 AM
Yes, I was driving it a week at a time before re-adjusting (about 200 miles total). They seemed a little better each time, but not good enough.
Took it for a ride today, first time since adjustment. It ran great as always and hopefully it's good this time. If not I'll try it at (2) turns out.
Thanks for the help! I'll let you know the results.
Old 05-08-2006, 03:27 AM
what do the instructions in your jet kit say. on my 7 its 2.5 turns out and you have to drill out a plug above the screw adjustment as well
Old 05-08-2006, 06:20 AM
I didn't have a jet kit for my bike. Stock jets for my bike is 160's outside/165 inside carbs. When I recieved this California model for some reason there were 150's across the board? Strange...
The bike had a K & N filter and a full Titanium exhaust. I figured bringing the mains up at 165 & 170 wouldn't be a bad choice? Or maybe 165 across the board would be better?
I also went back to the stock airbox.
The plug that you are speaking of, I think it's an air jet. Mine, being a Cal. model has an even smaller airjet than the 49 stater's. I have modified this bike to a non-Cal. model, except for this.
Old 05-08-2006, 06:44 PM
if you have a kn filter, full exhaust without a full jet kit, your going to run lean. eventhough you changed the main jets you still need to modify the pilot jets. spend the 100 bucks and get the kit and it will fix the problem.
Old 05-10-2006, 02:34 PM
I do understand that the pilot jets should also be replaced. but I also know it's not really easy to find Kehin Pilot jet's. I had a real hard time getting them for an earlier model Ninja a couple of years ago (but I was able to get them, for a price).
What I'm thinking is that the plugs I'm using are too cold? I'm not sure of the history of the bike, but the old plugs ran at a nice brown color last year even after re-jetting the main jets.
Does anyone know the difference between these (2) plug types.
When I bought the bike it came with CR9E plugs in it. The plugs also did not have the (2) electrodes on them, just (1).
Stock plugs are CR9EK with (2) electrodes on them. Are the CR9E plugs possibly a hotter plug?
I think I got the Hotter/Colder plug idea correct?
I also am running the Stock airbox with the screen removed, and not the K & N filter anymore. I had read that the K & N air filters actually make your bike run leaner. Not sure if that's correct, but that's just what I've seen on other forum's.
Thanks,
Old 05-10-2006, 05:11 PM
Try the NGK plugs, have always worked good for me.
Also like walight said, get a full jet kit and it will be better.
http://www.dynojet.com/pdf/2191.pdf
http://www.dynojet.com/jetkits/motorcycle/kawasaki.php
Call dynojet and they will ask you about rour bike, filter, exhaust and they will recomend the correct kit. There tech support is great too.
Old 05-11-2006, 03:17 AM
the only reason k/n filters cause a bike to run lean is b/c they allow more are into the air/fuel mixture, same with a high performance exhaust, thats why its recommended you rejet after modifiing anything with the air or fuel.
Reply
Thread Thread Starter Forum Replies Last Post
Air/fuel mixture screw thingy... What do you call it? klx-vn KLX 250S 18 12-30-2014 03:18 PM
Air Fuel Mixture Screw for $10 Brieninsac KLX 250S 1 05-21-2013 08:49 PM
Air Fuel Mixture Screw Help Vrede KLX 250S 20 10-28-2012 02:40 AM
Part number for the air/fuel mixture screw LordVngr KLX 250S 13 09-16-2006 04:49 AM
Air/Fuel Mixture screw location krntl13 KLX 250S 2 07-23-2006 03:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
