1999 kx80
Old 03-24-2011, 05:02 AM
riderlogie's Avatar
Default 1999 kx80
Hey, just got this kx80 for free, trying to fix it up but it wont shift any ideas?
Old 03-25-2011, 03:52 AM
It turns over, but it will not go into gear? See appendix 14-3 in your manual on shifting issues. there is a nice list of possibilities. Nothing is free, but a manual makes a give me bike worth having. but the gist is "The clutch not disengaging, the shift fork bent or sized, the gear stuck on the shaft, the gear positioning lever binding, the shift return spring weak or broken, the shift return spring pin loose, the shift mechanism arm spring broken, the shift mechanism arm broken, the shift drum broken... Good luck with the free bike
hinecken
12-26-2019 06:02 PM
chbronco
02-21-2009 11:58 AM
corey10
03-10-2007 06:43 AM
backflashh
01-07-2007 10:32 PM
Quick Reply: 1999 kx80
