I need help adjusting my carbs
Old Jul 7, 2008 | 02:00 PM
streetfighter87's Avatar
Default I need help adjusting my carbs
For all you guys that know much about a 1987 kawasaki ninja 600 plz do reply.
Bascially i just had my carbs cleaned by this professional near my house. i put em in and the bike ran perfect except one problem, It was pouring out gas like no other. So i thought how to fix this problem would be adjusting the mixture screws andobviously I waswrong. Now the bike now mater where i put the adjusting screws all it wants to do is rev high. there are also 3 screws on the top of the carb i adjusted which i believe sets the throtle for each carb or sync. i have turned down the idle all the way too if u think its that
well thanks for reading guys and hopefully i can get this fixed
Old Jul 7, 2008 | 02:07 PM
Kohburn's Avatar
Default RE: I need help adjusting my carbs
pouring out fuel as in running rich? or were they leaking when the engine was off?
Old Jul 7, 2008 | 02:52 PM
ford35's Avatar
sounds like float is stuck or not set at correct level.... 2 you need to sync the carbs but. need to fix floats first
Old Jul 8, 2008 | 02:56 AM
start out fresh and where is your manual? Cleanliness, float height(and seat condition), idle screw, main jet and needle height, with proper synchornization. Check the plugs often, etc.
Old Jul 9, 2008 | 04:56 AM
Prom's Avatar
I love the term "Professional" lol. To me it's just someone who does it so much they stop caring about their work. If the carbs were overflowing when you first put them on and started it then its probably your floats, You will have to take the carbs apart and make sure its all good, or ask your professional to fix his mistakes.
Old Jul 9, 2008 | 05:01 AM
NDstructible's Avatar
Definitely soundin like a float issue, +1 prom
Brieninsac
Mar 27, 2012 12:44 PM
Gecko
Oct 6, 2010 06:17 PM
Pepe72
Sep 17, 2010 01:45 PM
ScreamingBuckeye
Jul 23, 2010 04:28 AM
50 Slider
Jul 8, 2008 03:08 AM
