Wtf!!
Wtf!!
I had antifreeze get in my oil after I replaced my push rod seal. I drained the old replaced the pump with a new one and yet still antifreeze is in my oil. I started to pull the engine out but really don't wanna do that . I pulled the oil cooler off and it didn't have antifreeze in it. I do not know what else to check. Does anyone have an idea or can point me in the right direction.
Hi
i dont think it would be something from the push rod seal .. last time i had coolant mixed with oil the problem was the head gasket .it wasent leaking very much soo no noticiable white smoke or sweat smelling smoke was coming out from the exhaust . but i could clearly see the oil turning green after an hour ride . apart from the head gasket it could also be a non visible crack in the jug which i highly doubt ...
I would start with a compression test and orr something that works on nearly alll vehicles : take the radiator cap off fill half a bottle of coke/water/anything as long as its plastic and clear with putt the bottle upp side down in the radiator and start the bike . if you see bubles coming up the bottle on idle or on reving the bike just a little bit your head gasket is gone .
this video might help
I`m sorry for my grammer im not english :P
best regards Kyle
best regards Kyle
