DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
EX500/500R Engine Swap Problems
Old 06-22-2014, 07:53 PM
Bill87CP's Avatar
Default EX500/500R Engine Swap Problems
Hi I swapped engines I have a 1989 ex500 chassis with all the old electronics and everything. I swapped a newer 1997 engine from a 500r in. The engine sounds like crap and wont run now, and it was taken from a running bike.
My concern is that the ignition pack is setup different I noticed there is a difference between the two generations. I had to swap the stator cover to get the connections to line up correctly. If it is different could this be my problem? If so does anyone have any clue on how to fix it?
Thanks
GearHeadGTP
Ninja 500R
07-13-2012 02:54 AM
kali_ninja500
08-20-2007 09:00 AM
tycar86
10-04-2006 02:02 AM
kali_ninja500
Ninja 500R
09-12-2006 08:12 AM
farscrape
08-25-2006 04:51 AM
Quick Reply: EX500/500R Engine Swap Problems
