Ltd750 1982 Engine start problems.
Old 05-18-2013, 06:31 PM
ismar's Avatar
Default Ltd750 1982 Engine start problems.
Hello..
I need help here. Theres no sign of eltricity when i turn the key on?
I was riding, then i stopped. Then i wanted to ride again and turned the key on. When i pushed the START button engine just shutted it down. From then i cant start my bike.
What can be the problem?
Old 05-19-2013, 01:11 AM
You can verify your ignition switch with a multimeter. Hit up your factory manual electrical section. Good luck.
Old 05-20-2013, 02:48 PM
jeffzx9's Avatar
Welcome, Is. The short story is, on a bike that old, a multitude of things could be causing your problem. However, always start with the easy items. Double-check your electrical connections; battery, ground, starter, etc. etc. How old is your battery? Charging system working OK? Will the engine run if you bump-start it?
Let us know....
safeman
06-09-2015 12:47 AM
Lloyd
10-23-2014 10:14 PM
Israel-klx250s
03-04-2012 08:33 AM
thetinman69
Classic Touring Bikes
06-23-2007 04:00 AM
ZX_9r
01-07-2006 04:23 PM
Quick Reply: Ltd750 1982 Engine start problems.
