buzz from front end
Old 08-29-2010, 01:53 PM
rider021's Avatar
Default buzz from front end
I recently bought a used 07 Nomad that has the Cobra light bar. I am getting a buzz that sounds like it is coming from the headlight. I am going to pull the light cover and look inside. I believe it is the wiring vibrating on the headlight housing (that is what it sounds like). Any other suggestions? It only happens when running around 55-60 mph.
Old 08-30-2010, 06:56 AM
Prom's Avatar
Could even be the casing resonating. Check all your connections and bolts. If you cant find anything loose the quickest way to find the vibration would be to take the windsheild off and feel around the headlight while its buzzing. Happy hunting.
Welcome to KF!
Old 08-31-2010, 01:24 AM
rider021's Avatar
thanks, good suggestion about taking off the windshield
Old 08-31-2010, 02:29 PM
Fuel cap springs?
Old 09-01-2010, 04:11 PM
rider021's Avatar
further forward but thanks
Old 09-02-2010, 03:39 AM
This link may or may not help. Good luck with the issue. http://www.ehow.com/about_6370991_co...-problems.html
Old 06-21-2013, 12:45 AM
jakestoy2002's Avatar
Any luck finding it...... I have the same issue with my 08 nomad..... opened headlight number of times... even placed foam between wires and case.... still happens 55 - 60 mph...
ninja636lowell
08-09-2010 03:12 PM
Daves_636
05-18-2007 06:05 AM
taystyl
05-10-2006 09:09 PM
joe sprocket
07-20-2005 11:24 AM
Quick Reply: buzz from front end
