2007 Vulcan Meanstreak clutch problem
Old 03-18-2017, 03:30 AM
KayEeyeAre's Avatar
Default 2007 Vulcan Meanstreak clutch problem
I have a 2007 Kawasaki Vulcan Meanstreak SE. I just did a complete engine swap everything went well and it started up fine. I just need to do some fine tuning on the idle since it's a new engine. the new engine didn't have the clutch slave cylinder so I put my old one on the new motor. I changed break fluid for the brakes and it went fine. I changed the clutch fluid which is the brake fluid dot 4 and the clutch lever won't pull in at all. It's rock hard. Any idea on what happened or what's wrong?
Old 03-18-2017, 04:37 AM
MaverickAus's Avatar
Did you bleed it?
Old 03-18-2017, 03:07 PM
KayEeyeAre's Avatar
yes . it happened as soon as i was done bleeding it .
Old 03-18-2017, 10:34 PM
Sounds like a piston is stuck either in the master or the slave.
Old 03-20-2017, 10:56 AM
KayEeyeAre's Avatar
Default Fixed
i double checked on my old engine if I transferred everything and turns out, I forgot the rod. Simple, rookie mistake. Works great now. Thank you.
QUOTE=MaverickAus;534793]Sounds like a piston is stuck either in the master or the slave.[/QUOTE]
Old 03-20-2017, 10:06 PM
Lol easy done, glad you fixed it.
BigBadFord
07-27-2008 08:05 PM
windycity708
12-10-2007 03:26 AM
mnkibler
03-30-2007 03:25 AM
whah
09-12-2006 08:26 AM
LOWANDMEAN
02-08-2006 08:00 AM
Quick Reply: 2007 Vulcan Meanstreak clutch problem
