whining noise after letting off throttle
I'm noticing a recent noise that I'm hoping someone can help me identify. When I let off the throttle, I'm hearing a noise that is somewhere between a whine and a howl. The higher the revs, the louder the whine. It's not excessively loud, but certainly noticeable, and it is getting more noticable. I first noticed a faint noise within the last week, but thought I was hearing things. The last 2 days has seen the noise increase to the point that there is absolutely no denying it. If I pull in the clutch, it seems to lessen quite a bit.
2001 Vulcan 1500 Classic w/ 38000 miles.
Any thoughts?
Thanks,
ET
Any thoughts?
Thanks,
ET
I have not played with the different types of gear oil yet. So I do not have any recommendations. Use the standard stuff ( grade API Gl-5 Hypoid Gear Oil) and you can decide after that.
I was not able to get the plug out to check the final drive oil. I broke off the tip of a flat head screwdriver in the process. Is there a preferred tool to remove that plug?
On another note, I put the bike on a center stand and spun the rear wheel. I heard a lot of clacking coming from under the engine cover on the left (shifter) side of the bike. I also noticed the noise when pushing the bike in the drivway. I have never heard that before from my bike. Does this new symptom alter the diagnosis at all?
did you ever find out what this problem was? My 04 1500fi is doing the same thing all of a sudden. It can't be good! please let me know if you get this post. If any one else ou there can help with diagnosis I am stumped, and don't want to remove engine.HELLLLLLP
I used a "running journal" from another poster (on another site) as my instrucion guide. It was most helpful. Here is the link.
Vulcan/Mean Streak Bevel Gear Assembly
Check it out and let me know if you have any questions.
