Top end oil leak - Kawasaki Forums
Reply
Thread Tools Search this Thread
Old 10-04-2005, 06:38 PM
Default Top end oil leak
I have developed a small oil leak in the front cylender, from under the chrome top cover. Think it may be a gasket.
My question is.I was going to try some "Bar's Stop Leak" befoe giving a dealer 1000.00 to tear the motor out.
Any suggestions on using such a product.
Also, I had my oil changed 2 mts. ago at a dealer, he kind of over filled it. Could this leak been caused by an overfill.
What are your thoughts on Synthetic oil 1997 1500 classis, 24000 miles?
Thanks for any help
Old 01-23-2006, 10:35 AM
Default RE: Top end oil leak
Had a '95 1500-A model Vulcan (the old BUBF), and developed a leak from the same place, except in the rear cylinder. The first thing I did was the cheapest check. I checked the compression on both cylinders with a compression guage I got from Auto-Zone for about nineteen dollars (cheap investment, that, as I have used it on everything from determining when my son's two stroke MX'er needs a fresh top end to telling when it was time to get Ol' Blue - the worn out Chevy truck that my son I argue over all the time - a new engine). Long story short, the front cylinder was well within spec, but the rear was way down on compression. This led to a bit more investigation, and a hop over to a buddy's who has a larger assortment of toys than I do in his garage. He did a leak down test, and sure enough, the rear piston and rings had to be replaced. Had a complete overhaul of the top end....and since they can't do ANYTHING to this engine without taking it out of the bike, it's a MAJOR ordeal. BUUUUUT, at least I had the peace of mind of knowing that I had done what I could to make sure it wasn't a smaller problem that could be fixed with a cheaper solution. This occured at thirty four thousand miles....less than I would have expected. Oh yeah, had them go ahead and change out the POG for a brass one while they were in there. If I'm not mistaken, Kawasaki went to a brass OEM oil gear in '98. so if you do (and hopefully you won't) have to have them drop the engine, I'd get that replaced as well. Don't know what Kawasaki was thinking with the Plastic Oil Gear...but it's cheap insurance against a catastropic failure to have it changed out if the engine's already out of the cradle.
Reply
Thread Thread Starter Forum Replies Last Post
Recommended way to break in fresh top end (351) and new bottom end rebuild? jhoffy22 KLX 250S 6 09-26-2011 02:42 AM
DJ Needle Clip 4th from Top with 2 Washers on top? redixson KLX 250S 6 02-18-2009 02:44 AM
2001 ZX9R Top end noise 3cylinder General Tech 9 10-26-2006 02:54 AM
A new top end? mazdaboy873 General Tech 0 10-10-2005 01:37 PM
Top end noise Jkuchera Kawasaki Ninja Models 0 07-29-2005 10:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
