water pump leak
Old 02-01-2006, 04:17 AM
fullhouse's Avatar
Default water pump leak
need advice. I have a 1996 1500 Vulcan Classic. I bought it November '05 with just over 7500 miles on it.
It had a bad coolant leak from the weephole, I have replaced the water pump seal & cover gasket, and now it has a cold start coolant leak, it leaks out at the weephole (about a 1/4 cup) until it gets up to operating temp, then it stops. I have put about 50 miles on it since the seal replacement. no coolant in the oil. could the water pump cover be causing this problem?
Coots Magee
Ninja 500R
07-22-2012 03:35 PM
klxstiffler
03-21-2007 03:30 AM
nucci13
08-02-2006 06:34 AM
Marty
12-22-2005 03:23 AM
Quick Reply: water pump leak
