Final gear oil change
Welcome To Kawasaki Forums.
They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there.
Welcome to KF.
Not really sure on an answer to your question. The manual states API GL-5 Hypoid gear oil, SAE90 at above 5 deg C (41 deg F)and SAE80 at below 5 deg C. For the 94-97 models
A GL-6 rated hypoid gear oil can also be used.
Jutboy
04-21-2006 06:05 PM
